Re: How fast does your Mercruiser 120 push you?
Thanks HT, what would you recomend for pitch? Maybe drop down to 17 or 19 , my problem is I can't borrow so each trial is a prop purchase.
Thanks again Glen
Hi Glen,
Yeah it's a hassle if you don't have your own personal supply of props!
The best way to select what you should use first, is to determine what your drive ratio and recommended WOT RPM is. (is it something like 4400-5000 for a 120 and maybe 1.98:1?)
Then use a prop-slip calculator to get in the "ball-park" with what you have now. (be sure to use GPS for speed and verify your tach......some tachs are WAY off at the higher RPM's.........maybe find another tach and just see if it indicates the same as what you have now......) inaccurate RPM will throw EVERYTHING off!!
Go to a prop shop and buy that prop and ask them if they'll let you try it before final sale (most will as long as you don't take it out and plow it into the ground!!)
Using the following calculator,
http://www.go-fast.com/Prop_Slip_Calculator.htm
1.98:1 ratio, 3800 RPM, 21p prop and 12% slip (common for single prop runabouts planing) ------------I get about 33 MPH.
(remember that pitot speedo's are FREQUENTLY inaccurate which is why you should use an el-cheapo GPS......don't do it on a fast moving river though
I would try a 17p 3 blade prop on yours first.
Just about ALL engine manufacturers suggest "propping" engines (I/O, Inboards & Outboards) to *just* make MAX RPM (towards the higher RPM in the range) when lightly loaded at the pressure altitude (elevation) you will be running the boat.
This way, if you load the boat up or take it to a higher elevation, it will still operate close (although lower) to the recommended RPM range.
Regards,
Rick
