Welcome Guest - Sign Up today
No announcement yet.
Fuel Flow Meter Question - what you recommend
  • Fuel Flow Meter Question - what you recommend
    i would like to install a fuel flow meter this season. Boats powered by single Mercruiser 5.7L EFI.
    I don't want to spend a fortune
    From some research it looks like the options are:
    - Floscan 5500
    - Lowrance LMF-200
    - Northstar F210
    I have an older Garmin Chartplotter that is not compatible with buying the add-on sensor so i have to go gauge mounted in my cluster. Do all above work on EFI mercruisers?
    Anyone with any experience they can share or recommendations?
    Thanks!
    '85 Carver 3227
    Re: Fuel Flow Meter Question - what you recommend
    I have a Navman 2100 (exactly the same as the Northstar F210) in my boat, with a 4.3MPI Merc. Works a treat....
    Just one tip (with any of them). Try to mount the sensor so the fuel must flow up through it, improves the accuracy....
    HTH,
    Chris.....
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    The world takes on a whole new perspective when viewed from 100’ below.
    1972 Bertram ‘Bahia Mar’ 20
    2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
    (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
    • #3
      - Floscan 5500
      - Lowrance LMF-200
      - Northstar F210
      Thanks!
      Howdy,
      I have the Lowrance LMF-200 and an HDS-5 GPS/Sonar and a complete Lowrance-Net set up.
      I love it. If you have an HDS you don't really need the display but I do like it.
      • #4
        Some interesting information in this thread.
        http://www.baylinerownersclub.org/fo...ad.php?t=57205
        Robert
        1993 Bayliner 3288 "Hocus Pocus"
        351 Fords
        Converted to tuned port programmable EFI
        • #5
          And to round it out, I have the FloScan 5500 (5532) model. It also works great, so I don't think whatever you opt for will be a problem. It's pretty much not rocket science, so it appears they all do their jobs well.
          2001 Carver Voyager 374 'Stick's Competition'
          Something tells me I should be on the water....
          If I answer your upholstery questions, it's only because I've been doing it 20+ years...
          • #6
            I also own a Navman and the only suggestion I would make with that unit besides the previously mentioned vertical mounting, is that you shock mount it. The turbines in these transducers are very fragile so they must be protected from shock.
            • #7
              Well said !
              Had the Nav for 2 seasons. Very very accurate, after almost 92 gallons have gone through, it had an accuracy deviation of 2,6% !! Awesome !
              But... within these 2 seasons, I had to replace twice the little turbine impeller sensor. It stuck and needed replacement.. bugger.
              A few months ago, I got a Lowrance LMF-200 with relevant sensor, and seems to be as accurate as the Nav. However, cant tell yet about the sensor ...
              Yamaha 115 2T Mod. 1991
              • #8
                Also, I have a spare 231 or 20b sensor in my garageif you can find a deal on just the gauge. I would let it go cheap.
                "Reel Justice"
                Trophy 2059
                Bravo 1 Drive
                Mercruiser 5.7 250hp
                • #9
                  HA I have a 5500 Floscan cant beat it, got it cheap on ebay and if it is wrong and you get towed in they pay... what a guarantee.
                  "Reel Justice"
                  Trophy 2059
                  Bravo 1 Drive
