Welcome Guest - Sign Up today
No announcement yet.
‘97 4.3 Vortec Thunderbolt V ignition coil
  • ‘97 4.3 Vortec Thunderbolt V ignition coil
    As part of my 4bbl & intake swap, I’m looking to replace my current coil. Mostly because of corrosion that’s on my current coil.
    I figure, while I’m in there freshening things up with a complete tube up, new hoses, manifold and carb. I may as well replace the corroded coil with a new one.
    My question is, would there be any harm in running an Accel super coil/super stock coil or MSD Blaster II? I’ve seen the flame throwers, but have read a lot of negative reviews. I have a lot of experience with both Accel & MSD in the auto world, and know they’re good products.
    I figure if I could go this route, aside from freshening it up and cleaning up the engine compartment it would allow me to run larger plug gaps.
    any harm in running either the super coil or MSD?
    Probably not but could even try the super duper pooper scooper coil with zang bang 09 Electro lighting coil
    Sorry, but most folks get something else because of the cool name.
    Think of it this way, your motor was designed for a given fuel amount and spark. If you increase the amount of spark, the fuel may burn faster. Could say, what's wrong with it burning faster? If it burns faster then it not burning fuel as designed.
    Does this faster burning put more load of parts, don't know. Could it, don't know, anything is possible
    Will say this, the offshore go fast boat keep saying MSD saves lost of money on fuel. It does this by parts failing and getting towed back to the dock
    94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
    95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
    07 Seadoo GTX
    Merc Adults Only VP Adults Only
    G-Dad always said "First Liar doesn't stand a chance"
    • #3
      Wire brush your coil can an paint it. Youre then out $4 for the paint.
      Spending money on an accell coil is just throwing money away. The Thunderbolt ignition is better than most aftermarket systems
      Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
      1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
      Past Boats
      1970 Wooster Hellion - Merc 9.8
      2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
      1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
      What’s behind you doesn’t matter.Enzo Ferrari
      • #4
        Must say I chuckled a bit at this..
        I personally don't buy parts because they sound cool, but if there's a rationale behind them (hence the thought of wider plug gaps)
        But you do make good points. My thoughts were that the OEM merc. coil was about on par cost wise as the Accel, MSD etc.
        I figured if I was going to spring for one, why not potentially upgrade for similar costs if there's no drawback
        • #5
          As always, I appreciate your input Scott.
          Thanks again! not a fan of wasting money, but also easy to get sucked into replacing corroded old stuff when you're already knuckle deep in it.
          • #6
            99.5% of the time the corrosion is simply surface corrosion. thats why they sell paint in easy to apply spray cans....... that is part of maintenance.
            I would be more worried about your oil pan than I would a coil if you have that much corrosion.
            Past Boats
            • #7
              The engine is a reman quicksilver longblock, it was put in not long before I bought the boat in 2015.
              I had it pulled last March when a starter bolt worked itself loose and sheared itself flush with the mounting pad.
              when I had it out, everything looked good on the block and pan (aluminum pan of course)
              I think most of the corrosion is on the peripheral stuff (intake, accessory brackets, coil etc) and the coil isn’t “bad” and you’re 100% right, it could be touched up.
              it was just a thought since I’ll have it all disassembled this weekend anyhow.
