jkimball
- May 14, 2013
- 220
I ordered all the parts for my new 4bbl conversion, and I’m going to go ahead a freshen up all the ignition components while I have her apart.
With pulling the distributor to change the manifold, I’ll obviously have to reset the timing on this motor.
It’s a ‘97 Vortec 4.3. Im assuming it has Thunderbolt V ignition? From what I have read and can tell by looking at the module that’s what it appears to be.
A few questions
- what’s the procedure (pics are best if you have them) to lock it in base timing mode (I’ve read there’s a purple/white wire to ground somewhere?), and when timing is dialed in - at what point do I unlock it from base timing mode?
- For this particular motor, what is the setting? I know on older sbc and pre-Vortec it was +10 degree tdc. On the flame
arrestor it just says “see owners manual” that won’t work Bc I don’t have one on a 23 year old boat.
- timing marks, I’m used to having balancers with the timing marks on a decal, and metal front covers with the serrated tab on them... this only has one notch in the balanced, and a “groove” for a lack of better terms on the plastic front cover.
Am I to assume that in the absence of the decal and corresponding tab, That as long as this single notch lines up with the groove each time cyl. 1 fires, the timing is spot on? Could it really be that simple? Seems too easy almost.
Sorry for the lengthy post, not a noob to turning wrenches, but ECM controlled distributorless ignition has almost made me feel like one when it comes to old school timing adjustments
A few questions
