jkimball
- May 14, 2013
- 220
I have a ‘97 4.3 with 2bbl that floods and is needing rebuilding, also have some corrosion on the manifold. So, I figure if I have to consider replacing the manifold anyhow why not go 4bbl.
National Carburetor will build me an Edelbrock 500 cfm for $275 and I plan to use the Edelbrock 2519 (marine) intake.
my question is, other than re-bending fuel line to route to the new location, is the 4bbl throttle bracket the only other item needed for install? Maybe a PSI regulator to keep the carby happy at 6> psi
also, since pulling distributor and reinstalling - I assume I may need to throw a timing light on it?
thanks for the help
thanks for the help
