Re: Oil leaking
I had an '88 johnson 90hp and if I ran it in the driveway with the water muffs it would leak some oil for a few days after. Only a small amount out of the exhaust in the center of the prop and drip down the skag. It's just unburned oil because you are not running at temperature or with load.
