1991 Mercury 75hp 2-stroke power head "knocking" or "banging" noise
propgun
Engine starts and runs at all speeds OK (not really smooth acceleration) - would describe noise as tappet noise if the engine had valves. Engine is oil injected - may have a weak fuel pump. The noise seems to occur once per revolution assuming the idle RPM is around 900 from looking at the audio waveform because the noise happens every 65ms or so. I guess this also means that there is a problem with only one cylinder or the crankshaft? Earlier in the season, it did run on no oil for a few minutes - clear oil tubing cracked and drained the tank. Also, (not connected directly with the oil problem) the engine would stall at high RPM unless someone pumped the primer bulb. I bought a fuel pump rebuild kit and some new filters. Replacing the filter seemed to solve the problem so I haven't rebuilt the pump yet. When I took the video just before leaving the lake the primer bulb was not firming up even after a lot of pumps.
I live about 6 hours from the boat, had to leave before I could look at the plugs or do a compression check. I'm hoping that from the description above and the youtube video someone with some experience might be able to give me an idea what is likely the problem so I might be able to order the parts that are likely the issue and have them when I get back up there.
Thanks in advance,
Greg
1991 Mercury 75hp 2-stroke "knocking" or "banging" noise at idle - YouTube
wilts42
Re: 1991 Mercury 75hp 2-stroke power head "knocking" or "banging" noise
Thanks in advance,
Greg
just went through this, first do a compression check to know how the top end is. My knock was coming from the lower unit. I drained the lower finding metal shavings, so I know the gears or bearing in going out. My knock was very faint and across all rpms.
Dave1027
Sounds like a rod knock.
propgun
Dave and wilts,
Thanks for the replies. I agree it sounds like rod knock or maybe a reed valve. If it is rod knock then the compression for all three cylinders would check OK? I was thinking that I might be able to quickly find out which cylinder it is by pulling the spark plug wire on one cylinder at a time and see if the knocking goes away? Does anyone know if the warn part is likely to be the rod, wrist pin, piston, or crankshaft? Would I be able to tell there was play by moving the flywheel back and forth a little while checking for piston movement?
The sound doesn't seem to be coming from lower unit - I had read some posts about lower unit issues and that is why I rotated to prop - not that that makes any real sense...
There is one other piece of information I left out. When the kids got back from skiing they said the engine made a strange noise when they slowed down quickly. After I heard it at idle, I haven't run it fast for fear of the rod breaking free so I haven't heard this first hand.
I am leaning toward ordering all the gaskets I need to tear it down along with a rod and wrist pin. Are there any other things I will need to get it put back together?
wilts42
Dave and wilts,
If it sounds like a rod knock its the lower unit.
the sound is traveling up the motor making it sound like a motor problem. Take of the lower and hand rotate it, bet it sounds like gravel in there ! If left on the motor it won't sound or feel like anything is wrong so take the 10 mins and take the lower off. Let me know what you find out
propgun
I drove up to the lake last night and spent the day getting more information on what?s up with the motor.
The first thing I did before starting it was pull the plugs. The plugs in the top two cylinders have a black bumpy substance between the outer ring and the electrode. The bottom plug does not have the black stuff (carbon?) you can see the insulation.
I took off the flywheel cover and carefully rotated it to try find any play in the rods. I was trying to find out if I could detect any issues with one cylinder 0 , 180 vs the other two relatively at 60 and 120. I had read about this in another thread for a two cylinder motor. Anyway I couldn?t find any difference between the cylinders. There may have been a fraction of a tooth of play.
I put the plugs back in and ran it at idle about 1000rpm to get it warmed up to test the compression. I used the cheap and horribly reviewed harbor freight US General item 66216 compression tester. I?m mentioning this because most of the reviews state that it doesn?t work at all or it reads low. [I picked it up before I was able to read the reviews] Anyway, the readings I got were 95 for the top cylinder, 100 for the middle cylinder and maybe 98 for the bottom cylinder. So at least I know they are about the same. I?ll see if I can get a better tester tomorrow morning.
I removed the fuel pump and opened it since I had a rebuild kit. Good thing I did because both of the check valves had partially failed. What I mean is that the outside of the ?rubber? disk was no longer completely covering the spoked holes. The valve on the front side where the oil pump output is connected, was only covering one quarter of the hole, and the disk on the back was only covering one half of the hole. [I?ll try to post a picture since this probably doesn?t make sense]. I assume that because of this the engine was likely running lean and without enough oil.
Given that I have never had to or thought I had to do a decarb, I decided to do that and the procedure that looked good to me was Ran Dunks Decarb Procedure. Ran Dunks Decarb procedure this weekend. sixth post down. I got a fair amount of white smoke but not huge amounts.
After the decarb, I ran the engine for a while on fresh gas (the gas in the boat gas tank is at least 10 months old) and it ran pretty well in the lift. I ran it up to 4000 rpm and then back to idle a few times and didn?t hear anything alarming.
There is still the noise but I think it has gotten a lot better. When I put it in gear at idle the noise almost goes away. I don?t know if this makes it more or less likely that the problem might be in the lower unit.
propgun
Wilts,
I really don't have enough experience to identify rod knock but the people on this forum and other local techs have come to that conclusion by listening to the audio I posted with the youtube video in my first post. Did you listen to that? Did your engine sound like mine?
Thanks,
Greg
wilts42
Wilts,
Thanks,
Greg
your saying that your noise goes away when its in gear and that doesn't match up with what mine was doing. you could rule out the lower by changing the oil and checking the magnetic plug and oil for shavings or shiny stuff.. If you de carbed and it acted better maybe your on the right track.
jagans
1. Fix your fuel pump. You have both check valve disks installed, You only want the ethanol resistant ones in there. The black disks are distended, which will allow fuel to back into your vacuum port and cause ping (pre-Ignition) This sounds like a rod knock. Sound Familiar?
2. The two plugs on the left appear to be shorted to ground with carbon. Ditch those center fire plugs. They suck in older engines with carbon buildup because carbon has only a very small gap to cross before the plugs short out. A regular plug has sort of a tower of porcelain that takes longer to bridge. Open up the gap to about .050" Your CD ignition can handle that gap easily. Keep a spare set on hand and buy that little plug sand blaster and extra media fro HF they really work pretty well.
Report back after doing these two things. Dont go tearing your engine down just yet.
snowbrd84
Did you check compression? I beleive the fuel pump runs on the #3 cylinder, low compression could result in fuel pump not pumping enough fuel at high rpm. Also, something is wrong down there, may explain the sound as well...
propgun
Thanks for the response and suggestions. The first thing I did when I heard the knock was to rebuild the fuel pump and run a gallon of gas with a whole can of Sea Foam to try to do a decarb. I didn't put in new plugs given the decarb would probably foul them but the "knocking" noise was still there after that. Could be the plugs, I suppose. I finally pulled the power head today and have it in my car to take home. I'll post what I find after I get the crankcase cover off. I know there is still some carbon on the piston heads at least it looked that way with the inspection camera images posted in a different thread.
propgun
Thanks for the response. The compression results with the throttle plates open and the engine warm were 110 - 105 -110 (T-M-B) which is on the low side but the HF compression tester I was using might be reading low. I went ahead and pulled the power head. Tomorrow I'll crack it open and see what I find. I hope it doesn't turn out to be the oil pump (fuel pump has a hose to cylinder 2, oil pump is lined up with the bottom cylinder). Of course, the middle cylinder might be cylinder 3 in firing order - I haven't looked that up.
Dave1027
Plugs can't make a knocking noise. Did you do as Wilt said and try running the motor with the lower unit off?
propgun
Dave,
It makes the same noise with the lower unit off. I was able to push a 5/8" piece of garden hose over the tubing in the exhaust housing after I pulled off the seal so I could run it for a while. Didn't need a hose clamp - nice tight fit. Had to lower the boat until the bottom of the exhaust housing was under water to hear anything. The power head is now in my garage - having trouble getting the crankcase cover to break free. Plan to pound "alternately sidewise" on the bottom of the crankshaft a little more with a bigger plastic mallet and see if that does the trick.
Djknyork
Resurrecting this post Have same motor with what sounds like the same problem & am wondering how this turned out
GA_Boater
Why? Start a new topic. This one seems to have no resolution. propgun hasn't been here since April. Please do not reply to topics with no activity for 90 or more days.
