I have 1980 Mariner (Japanese Model) 2 cylinder 60HP. I had it out on the water a few week back, hit a huge amount of wake from another boat and the motor died. Pulled off the engine cover to find a sheared the flywheel key, damaged the flywheel keyway, and sheared off the starter cover shield. I replaced the following:
1) The flywheel was replaced with a working spare.
2) The flywheel key was replaced with a new one.
3) Flywheel torqued down to specs in my Mariner 48/55/60HP shop manual.
4) Starter cover shield replaced.
5) Fuel filter replaced.
Suspected problems that have been ruled out (at least by me):
1) The top of the crankshaft and the crankshaft keyway is still good.
2) No visual damage to magneto base and trigger components under the flywheel.
3) Compression is still an even 120 psi in each cylinder.
Suspected problem:
The motor starts ok in neutral, but it dies out when you give it throttle. I got it out of neutral once without it dying out and the top speed was about 5 mph and it sounds like the engine is misfiring or missing completely. I think it may be a timing issue because I replaced the flywheel with a different working one. I've never messed with the timing on any outboard. Any thoughts or suggestions for testing or possible problems other than timing?
Suspected problem:
