I was told a recent problem I had with my MerCruiser 40HP outboard motor was because I had the wrong size battery attached. According to the mechanic I needed a minimum 800 CCA battery and I had a 495 CCA.
Can someone please explain what happens with the wrong size battery?
Will it cause the outboard to work HARD to charge the battery?
Thank you,
Ron
Thank you,
Ron
