Welcome Guest - Sign Up today
No announcement yet.
yamaha mariner 60hp cdi wiring 1983
  • yamaha mariner 60hp cdi wiring 1983
    Hi all, I bought a boat with mariner 60hp motor, engine No. 6FO 302375 belive to be 1983 year. Was told needs new power pack (cdi). A boat wreckers sold me a TIA-02 but connections are different, mine bullet connectors. Does anyone have wiring diagram for this motor, any help appreaciated.
    Re: yamaha mariner 60hp cdi wiring 1983
    That s/n comes up as:
    60 EL 6F0-301585 - 6F0-305060 1982 2-Cyl, Japan
    From here:
    Parts Listing:
    Mercury Parts, MARINER 60
    See CDI unit, item 40 under IGNITION SYSTEM
    Here is a link to the condensed version of the Clymer service manual. Download it soonest as the link is short lived.
    Small Engine Repair Reference Center Home
    The bullet connectors are no problem as you can always change them but as this is such an expensive part, can you say how much you paid for the one from the salvage yard and do you have a complete number, ie; T1A02-??
    Gerry
    • #3
      From here:
      Parts Listing:
      Gerry
      Its a TIA-02 12 004 was $200au. thanks for the manual.
      • #4
        From this list if you select Ctrl and F you can type in the numbers 83030M and you will see that it brings up the CDI p/n: 117-TIA02-12
        http://www.cdielectronics.com/downloads/CRPL.pdf
        If you type in 98715M, the CDI p/n is: R6F0-85540-10-00.
        As best I can find is that the 83030M is for the 60 hp engines with s/ns beginning with 675.
        The 97815M is for the 60 hp engine with s/ns beginning with 6F0.
        You could send a message to Faztbullet here on this site as he may know if they are compatible or contact CDI but at the moment, it seems that you have one for engines beginning with 675.
        Gerry
        • #5
          Gerry
          I was thinking if i buy the stator that suites the TIA02-12, the wire colours will match up,
          my stator has no blue or yellow wires, but has 2 green wires
          • #6
            This could start costing you a lot of money. As most of these components are Repair and Return at CDI, I suggest you contact them:
            CDI Electronics: Technical Support and Service
            and query them about what you wish to do.
            Gerry
            • #7
              [QUOTE=carholme;4053963]That s/n comes up as:
              mine is a 60E not EL
              98715M looks like the right CDI
              the manual you linked to me is different
              • #8
                L just means a long shaft
                If you look at the s/n list I sent you, you will see what that s/n brings up and it states that yours is a long shaft engine. Is it a long or short shaft.
                As stated in my previous post 98715M is the right CDI for your original setup. However, you are now saying that you are going to use a T1A02-12 which is not the correct one for engines which begin with 6F0 as yours is. It is for engines which begin with 675. The reason I said to contact CDI is that I cannot confirm the compatibility.
                As far as the manual goes, the 6F0 series engines were only available in 1982/3 so if that manual is not the correct one, I do not have another one.
                Gerry
