1988 Force 85 HP Ignition switch wiring diagram
I need ignition switch wiring info for a 1988 Force 85 HP outboard; My old switch is a 3 position, push to choke with 6 posts; labeled counter clockwise with post (I) appearing to be off position; I, M, B, C, S, M; it has a 1 in barrel. The only replacement switch I can find (F5H268) 1/2 inch barrel..has different post markings; labeled counter clockwise, with post (B) as off position; B, M, A, C, S, M. The wires on my harness to old switch; I-red wire with blue stripe; M-double white; B-double red; C-green; S-yellow; M-Blue. Does anyone know how the wires should be connected on new switch?
Thanks
Any help greatly appreciated.
