Hi Guys,
Picked up a merc 90 hp inline 6 with out power trim.
Just got. A 3 wire power trim this motor normally has
2 solenoids one for up the other for down. I picked up a. Johnny control box
With 2 relays inside. Hook up the first relay worked fine up using the blue wire
Then switched to green wire to check trim motor to see it go down it did worked fine
So I. Hooked up the other relay and the problem occurred. Motor going down was slow its like
By hooking up the other relay it actually cut the power. Any of you Guys have the answer it would
Greatly be apppreciated.
