RedRanger1
- Feb 3, 2011
- 2
Is is necessary to remove the lower gear case in order to change the motor mounts on a 1994 Mercury 115 HP Outboard?
If that is the case do I need to remove the prop in order to remove the lower gear case?
Thanks for any help!!!
