robcobtheplumber
- Jun 13, 2010
- 4
I just bought a 40 hp mercury 95 model oil injected and it will idol around the lake all day but when you throttle up it will run about 30 sec, and cut off (starving for fuel ) so I checked the primer ball it was fine checked fuel filter and carbs they were clean , I checked the compression on the engine 1,2,4 have 120 psi and 3 has 30psi so does the compression affect the fuel delivery system?
