Mercury 3.3 HP gag/oil mix 2003
fishon71
Can someone advise the proper ratio of gas/oil for my 2003 Mercury 3.3 hp two stroke outboard motor?
Thanks
emckelvy
Re: Mercury 3.3 HP gag/oil mix 2003
Mix 50:1 with quality mfr's oil rated TCW-3 or better. Use regular unleaded non-gasohol if available, if all you can get is gasohol use regular, your little kicker won't need any more octane than that and higher grades have more alcohol which is less-than-desireable.
Use a carbon-cleaning additive at least several times a season, this'll keep your rings from sticking. Seafoam is great stuff and also acts as a fuel system cleaner & fuel preservative. www.seafoamsales.com
If you can't get Seafoam, all major outboard mfr's offer carbon cleaning additives and fuel conditioners. Chevron Techron additive works well, also.
HTH & enjoy........ed
fishon71
Re: Mercury 3.3 HP gas/oil mix 2003
I thought these newer motors ran on something less than 50:1 , no ?
emckelvy
OMC flirted with 100:1 ratio's for a while, if that's what you mean by "something less than....". But I didn't think that Merc went radical on any of their little non-injected motors.
The biggest problem with 100:1 was that it left too little of a residual oil film in the crankcase, to preserve bearings and other sensitive parts while the engine sat for a long time. So the parts would begin to rust. Not a good thing!
Far as I know, all the non-injected Mercs ran 50:1 in 2003.
Piqued my curiosity so I Googled and found this Wiki entry that indicates a 50:1 mix still:
http://wiki.answers.com/Q/What_is_gas_to_oil_ratio_for_a_3.3hp_mercury_outboard
Can't confirm that source but it seems evident that 50:1 makes sense.
I'm sure someone with an owner's manual can confirm.......ed
TOHATSU GURU
The engine was actually designed by Tohatsu to run at 100:1 and will do so without any problem. The reason they were only released as 50:1 engines was due to the fear that people would not perform routine maintentanice on the cooling system and that the engines would not last long with reduced water flow through that coolant system.
sundowner205
I have the Merc 2.5 hp - same motor just a smaller carb. I found out today that the motor is actually a Nissan/Tohatsu from TOHATSU GURU. Apparently all Merc's up to 30 hp are Tohatsu's.
I needed a replacement carb and the Merc dealer wanted $165 for just the carb. Per GURU's knowledge, I called the local Nissan Marine/Tohatsu dealer and got the carb for $90.
If you ever need parts for that motor - go through a Nissan/Tohatsu dealer - same parts but almost half the price. :D
kripton
is this ratio available for the 3.3 hp mercury two strokes from 1996 ?
