Hi,
Since yesterday I have a higher RPM at idle. It is a mercury optimax 200 from 2002 with 540 hours.
You have to know that:
Is it because one of the 2 batteries was empty?
Is it something else?
EDIT: on the smartcraft the sign TRIM with arrow blinks every 5 seconds...maybe this helps
- the engine was not running for 2 months
- one of the two batteries was empty
- it started immediately
- after 10 seconds goes up from 650 rpm to 1150 rpm
- engine is flushed with muffs
- after giving more throttle and go back to neutral, the engine still runs at 1150 rpm
