My oil injection failure warning horn went off again today. I switched right to a spare premix gas container and idled bake to the dock. Does anyone know where I can get a oil pump cover kit so I can just run pre-mix from now on. I checked the oil pump nylon adapter and steel driven gear and they looked good. The engine puffed a good exhaust stream of blue exhaust smoke at the dock, but the blue stream was not there when I turned it off from the alarm today. And how do I turn off the oil alarm by the boat key. Can I just cut the 2 wires going to it and solder them together? And what about the oil pump sensor right above the oil pump that detects when the pump is not turning, how do I disable that sensor. I have no faith in the oil injection system and want to remove it and forget it. This engine is driven at mostly cruising speeds and the extra smoke from premix is no big deal. Any comments would be appreciated.
