need firing order "81 Mercury 115 inline 6
Status
Not open for further replies.
dk00913
Re: need firing order "81 Mercury 115 inline 6
if the firing order is wrong could this cause the engine to run ok at idle then bog down under loads :confused:
jch7450
hello all in line 6's are 153624
Yepblaze
Bogging under loads is most commonly a fuel starvation issue.
dk00913
I was told the plug wires go straight across #1 to #1 cylinder and so on is this correct
BIGKASH
i have the manual that a has firing orders and i dont see the any of them thats 153624 as posted before, i'm not sure what motor u have but i'll post this<br /><br />merc 90-140 hp 6 cylinder with distributor-less ignition is 1-4-5-2-3-6<br /><br />merc 900 1150 1400 1500 and 1500xs distributor cd ignition is 1-4-5-2-3-6<br /><br />v6s firing order are all 1-2-3-4-5-6 in my manual<br /><br />good luck
dk00913
Thanks....think my problem has been found though fule troubles but stripped the top carb and made a world of difference
Possible stupid question but is it possible to convert inline 115hp 6 distributor/trigger system to electronic, ive been given a complete new charging/EI system
Status
