I have read other posts with similar issues, but a little different. I will try to keep it short. Bought a carolina skiff with 1998 mercury 20 hp. Really hard to crank. Choke mechanism seems to work but won't help crank. Pull to prime knob doesn't seem to change idle speed at all. Have to use starting fluid to crank. Once cranked, will idle at times for long periods of time. If i throttle up slowly it stalls. Have to go quickly and then usually will sound good and rev up. But then when you go full throttle dies. Won't go more than 5-10 seconds at full throttle.
what I've done- new fuel and oil with seafoam added. New primer bulb. New spark plugs. New fuel filter.
Taken carb off and cleaned, but not sure how good.
I have verified fuel is good to fuel filter and primer bulb is full of fuel when engine dies. Carb bowl also full of fuel.
Does this still sound like clogged carb? Thanks in advance
