brexitsmuggler
- Aug 11, 2020
- 4
Hi,
i have a Mercury Thunderbolt 85hp outboard that came with a boat i bought. The outboard was was partly dismantled and had not run for approx 2 yrs.. I fitted a new starter and did some carb and wiring repairs and was delighted when it actually started and ran very well. I used it throughout the summer 2019 without any problems. It always started and ran very well. Its a great engine for its age. It was previously used on fresh water and this was first time running in salt water.
It was parked up under cover for winter 2019...then when I put it back in the water June 2020 it would not turn over.
I put a breaker bar on the fly wheel nut and it will not move a millimetre in any direction. Its Locked solid.
I pulled the plugs and went through various routines of filling the cylinders with various mixes of wd40/diesel and anything else i could think of. after 4 weeks it still wont budge in the slightest.
I removed the lower unit and gearbox /drive shaft. Everything fine there. I removed the two side panels on the cylinder head and can see the 4 pistons and lower cam shaft brackets. Cannot see any corrosion or anything else wrong.
when using the breaker bar i can feel the camshaft and piston arms and pistons trying to move ever so slightly.
I am a total amateur in this field and it has me perplexed how the engine could seize like that after a few months?
its almost as if there is a locking mechanism engaged preventing the engine turning over!
Anyone have this problem? Could the salt water have seized the engine that fast? or am i missing something simple?
