Andrew1346
- Jul 6, 2020
- 6
I recently inherited a Starcraft super sport, late 60’s. Powered by a late 70’s mercury 850, it’s hasn’t run in probably ten years. I put a new water pump in it, plugs, fuel lines and resealed the carbs. Tried adjusting the mixture screws on the carbs with muffs in the yard. I’ve taken it out on the lake, it doesn’t want to idle at 1000 rpm, which is still too high I know. I go to get on it and it bogs out, I richen the mixture screws out until it accelerates good, it will run decent at the higher rpm’s, above 3000. But as soon as it comes back to an idle, it will not accelerate again, almost acts like it’s loading up-too rich, but I can’t seem to get it tuned back once it’s warm to get it to run right again. Haven’t checked the timing yet, other things to check?
