Water pump kit
tblshur
At the lake trying to help my neighbor no water coming out tale tale boat quilt yesterday was towed in thought it was battery before he went out today I checked tale tale no water he got boat last year I have looked here and other places and can’t find a kit pt # serial 1c115663 mod 1a40413kz 2011 40hp mercury thanks for any help
ThomW
I am guessing you are looking for the water pump kit? If so, 46-812966A12 is the mercury part number.
before going right to a new impeller, have you tried shoving a piece of weed wacker string or similar item into the tell tale hole? Quite often little critters like to build nests in the hole/tube and will block water from pumping out. Especially after sitting all winter. Worth a shot before you replace impeller.
