SteveVT
- Jul 31, 2017
- 163
Hi Ihave a n '89 Mariner 25hp EL with a WMA 32 carb that I'm re-building.
What should I set the carb float height to?
Also, just checking, re. the fuel pump on the carb -- diagrams and videos I've seen show a single unit for the diaphragm and gasket. My kit came as separate diaphragm and gasket. Because I can't find a clear drawing with the parts separated, I'm guessing that the gasket goes against the outside plate, and the diaphragm is next, and bears against the nylon pump body -- is that right?
Thanks!
Thanks!
