monstertails
- May 13, 2013
- 59
I just picked up an 1996 pontoon with a 96 75hp Mercury and I replaced the complete water pump and fired it up. I am getting water mixed with exhaust and when i remove the brass plug just above the top cylinder it sprays out with good volume but there is a hose that comes off the top side of the block end exits out the side of the outdrive that I assume is a telltale and it is bone dry, unless this is some type of crank case breather. Can someone please assist me with this issue? Thanks in advance.
