I believe the PTT cylinder rod is one piece. The good news is that the are pretty tough and some rust is fine. See how bad the rust is, and go from there.
You might check the rod that the bottom of the cylinder is on. That is replaceable, but a real PIA since it is captured within the triple clamp.
