Welcome Guest - Sign Up today
No announcement yet.
95 Mariner 90hp won’t shift in gear when running
  • 95 Mariner 90hp won’t shift in gear when running
    Hi all, wondering if anyone has an idea on a problem I’m having. I’m pretty stumped. I have a 1995 mariner 90hp 2 stroke outboard, ran great until last weekend. I was going wot and all off a sudden the motor rev’d high and I lost the ability to put it in gear with the shifter. Got myself back to the ramp and got it home. Took the lower unit off and got it back in gear with pliers. I assumed it was a fluke, put lower unit back on and it shifts fine dry not running. Seemed like it was back to normal. Take it out today and it won’t shift into gear again running. Shut it off and it goes into gear with the control. Any ideas on what needs to be addressed here? Thanks for the help.
    Tried another propeller ?
    • #3
      I have not but I do have one and I will try that right now
      • #4
        Not the prop. Brand new prop same issue
        • #5
          Drain the lower unit / inspect gear oil.
          • #6
            So further investigation, ran the motor, shifted into gear, killed engine and the lower unit was in gear when it was off. Problem with the driveshaft?
            • #7
              Suggest your adjust shift control cable a hair
              check to see if came loose both ends
              • #8
                I believe it’s going to be the driveshaft pinion Gear, or something related to that, checked gear oil and there’s metal chunks.
                • #9
                  There you go some simple inspection and you have an answer.----Not going to be a cheap fix.----Perhaps search for a used lower unit.
                  • #10
                    Tore it down yesterday, pinion gear decided to blow up in 3 pieces. Forward and reverse are toast, in addition the driveshaft splines are also toast. Will need a total replacement. Never took one of these apart before. It was much simpler then I had expected. The only thing I can’t figure out is how to get the driveshaft totally out. After taking the nut off the bottom, it seems there is a bearing or something pressed into it stopping it from sliding out, any ideas?
                    • #11
                      Lots of used and new Mariner pinion gears on ebayy FYI. got a part number?
                      • #12
                        SEI is your friend.... get a new one as not worth rebuilding.
                        When in doubt,Trim it out!!!
                        Business Owner & Certifed Technician
                        Boats I own & use
                        20ft Javlin w/250 Junkrude
                        17ft Bullet w/200 Merc (SOLD!!)
                        13ft Allison w/150 I-6
                        17ft Hydra-Sport 175GT
                        15ft Allison w/75 Stinger(project)
                        14 x 48 Drifter with 1100SS Merc
