Welcome Guest - Sign Up today
No announcement yet.
Extended trim anode of no use !
  • Extended trim anode of no use !
    Bit of a bugger today. After previous posts about trying to counter act my horrendous torque steer at slow speed and low planing speeds...some will know I managed to buy the extended trim tab anode that normally sits out the way of the larger props.
    turns out...even they don’t sit far enough back to allow the enertia to swing. Not a happy chap today.
    just thought I’d let others know.
    I’ll either need to put up with it, cut a small section away or just do what is really required and get proper steering system.
    You wouldn't like the tab anyway, you would start gripping it took some top end away
    94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
    95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
    07 Seadoo GTX
    Merc Adults Only VP Adults Only
    G-Dad always said "First Liar doesn't stand a chance"
    • #3
      Now I'm sorry I tried to help when you asked a while back about extended trim tabs.
      Those Enertia props are worthless.
      BOAT SPECS | FORUM HELP | STARCRAFT FORUM | SHOP iBoats
      Please, no PM's (Private Messages) regarding boat/engine problems.
      That is what the forums are for.
      Only forum/moderator issues will be answered in PM's.
      • #4
        There is a wedge-shaped piece of metal that can be attached to the skeg to counteract torque. They may be called "torque Tabs" or something like that.
        I made one for my speedboat, as at high speed, the trim tab anode is out of the water.
        • #5
          Haha. Bit of a bugger. It’s marginal but only just comes into contact. Oh well. Worth a try.
          • #6
            That thought did cross my mind AD 😂
            • #7
              If it "almost" clears, some slight shaving is probably be OK. Unless you can return it.
