mckinney004
- Jan 26, 2016
- 46
Situation/background: Recently purchased a 1993 Lund Baron 2100 GranSport with a 1993 Mariner 175 EFI Magnum serial# 0D188725 (not sure if that is a "O" or zero). That is an oil injected 2 stroke. Long story short, I bought the boat from an elderly man who purchased the boat, had it tuned up, then had a stroke before he could ever use it. The boat sat for 8 years before I purchased it a week ago. Now I'm trying to fire it up.
Analysis: Compression is good. Cylinders are lubed up. Spark to all 6 cylinders. I don't appear to be getting fuel to the cylinders. This is my first big outboard, first EFI, and first oil injected motor. I have quite a bit of experience working on older/smaller outboards. I have found a couple small fuel/oil lines that were dry rotted and broke when I touched them. None of them are release much, if any, fuel when I crank the engine.
Request: Can anyone explain or point me in the right direction about the path of fuel from the fuel line connection to the cylinders? I also plan to disable the oil injection, and premix my oil/fuel. Is there a way to rig that by simply blocking oil lines, or does it REQUIRE actually removing/replacing parts. I'd prefer to just block off the oil supply and pull fuel+oil through my main fuel line if possible. I would remove/replace parts if required though.
Thanks everyone in advance.
