Brad Fideldy
- Jul 19, 2019
- 5
Bought a boat recently 2004 20' Procraft with 1998 200EFI. Boat lacked power on take off and then felt like it ran out of gas and quit. Fuel pressure is zero, so basically bad fuel pump
Issue is though the guy I bought the boat from said that the fuel pump was rewired to a keyed terminal because some high limit module went out. So now basically when you turn the key to on the fuel pump has 12 volts constantly. He said his mechanic told him this was common instead of replacing the $500 module.
Question is......did this rewiring cause my fuel pump to fail? the wiring was changed 8 months ago. I don't know that the fuel pump should have 12 volts to it all the time or if it should modulate to lower voltages depending on the demand from the motor. Some cars run on 12 volt all the time, but they also have a fuel bypass line. Seems like running the pump to max output may be why it failed to begin with.
I don't want to replace and have to put in another pump in a few months.
