I have a 96 115hp off shore engine that’s needing some parts and tune up I’m guessing. Not sure the best place to buy what I’m needing. Going across the lake WOT the engine seems to lean out. No difference between 75-100% on throttle engine backs off few hundred rpms you can hear it change sound but it’s not instant it’s over a few mins. If you bring back to 50 percent for little while then back to wot it picks back up great again. I looked at the primer bulb and it’s not sucked down. So I was going do a tune up. Plugs plug wires, fuel pump rebuild, speedo tube and then there two rubber mounts at the bottoms of the engine that’s gone I’ll need to replace. I’ll post pic of that. Thanks for any advise in advance.. I did a compression test on it last night all in the 120s. The plugs didn’t look like they been running lean either in my opinion
