Hello all! Long time lurker, first time posting.
I have a 1999 Mercury 200 XL Saltwater Carb 2s- Serial #- OG803976
I have been having some trouble lately with the electrical system and wanted some advice.
About a month ago, I had an issue where the starter would just spin but would not engage the flywheel, I changed the starter solenoid and the starter and it fixed that issue. Soon after I was on the water one day and after several starts and stops and running and idling all day while using the stereo and various other electronics, we stopped at a marina for about 30 minutes and the motor would not start, it would turn over but would not start until I finally wore both batteries down although it still cranked it would not start or run. Towed it back and before I did anything else to diagnose the issue I charged both batteries overnight. Came back the next morning and the boat fired right up no issue.
Was working on the boat yesterday and was running it on the muffs and noticed the temp gauge was dead, diagnosed that to a loose ground in the head that holds the temp sensor in and just went ahead and replaced that as well while I had it off. Works fine.
I charged both (brand new) batteries before we left for the ramp and boat cranked right up and ran beautifully, idle, mid range, WOT, up on plane all good. I checked my analog volt meter on the dash was reading right at 12 no matter what RPM I was at, checked it on my Garmin and was reading at 12.5 while idling or mid range RPM and 11.9 WOT. I had the stereo on for the kids and my GPS running besides the motor. I usually flip my bilge on when I am running for a few seconds to check for water (usually a little, but I have OCD about it). When I pushed the bilge switch the GPS and the Stereo completely shut off. I killed the bilge, turned everything back on and it was fine. The motor never even blipped. Went to dinner, shut both batteries off, came back fired right up and headed out (Stereo and GPS again, no problem) it was dark so i put the nav lights on and my LED strips under the gunwales, still fine. Flipped on my rear spreaders for a second and bam, everything electronic went out again, motor still running great. turned the spreaders off, fired everything back up and ran great.
Haven't had a chance to check the batteries yet but will tomorrow morning, I am guessing that they will be very drained.
So after my life story, my question is, the theory among the firefighters round table is either the stator or the rectifier. I do not have a flywheel puller but can get one and probably take it somewhere to be checked but I was hoping for some insight or experience to determine what this could be? Of course the Stator is close to $600 for this motor (all the other Mercs are $169!). I know I could take it to a Merc repair shop in town but I am pretty mechanically inclined and like to do things myself if I can but if I have to I will take it in.
My theory is if it was the stator, it would (or should) affect the running of the motor, like no power to the coils, missing, falling on its face etc, but the motor runs perfectly, I REALLY stay on top of the maintenance and the motor is like new. However if the rectifier is not working it is just not putting the voltage back into the batteries and everything is running off the ever depleting batteries? Just a theory, I am sure someone out there knows WAY more than me.
Thanks for reading and any help would be appreciated.
