know nothing about outboard what oil should I put in the lower unit I also just got the motor and cleaned out the carb. What shall I check or do maintenance on?
That motor needs Lubriplate 105 in the LU. - gear oil leaks past the seals; this has been discussed to death on another forum that deals with old Mercs. The oil mix is 20:1. originally but with today's oils 50:1 would work.
