stator ohm ok looks almost new
trigger ohm ok no sign of damage
rectifier checked ok
flywheel is good
timing is correct
change stator wires to switchboxes still only 1, 3 and 5 firing.
disconnected bias wire no change
Any suggestions will be appreciated. I'm thinking bad switch boxes.
This started with not getting over about 2000 rpms on the water and after about 5 min it suddenly went full speed and worked fine the rest of the day. Next time on the water it would only idle. any advance of the throttle it would stall and shut off
flywheel is good
timing is correct
