The motor is 1977 mercury 1150 inline 6 with distributor. It idles in neutral at 1000 rpm and in forward at 650 rpm. I can still feel the uneven breath when in gear at 650 rpm. It still has a hard cold start for about 20 - 30 sec.
I think I may find out the reason. The bleed hose at the air bypass side has a tee connector installed. I am always curious about that but think it should be what it is. I read some topics today and find out it is the path to pump the left oil from lower to upper side and there should be no leak.
Here is what I found out when inspecting this bleeding hose.
1. There is a tee connector installed in the hose. It usually spits out some fuel when running. This is not right, is it?
2. When I try to suck and blow air to both up and down side, both have in and out path without blocking. Is this normal? Because I remember raceone said there should be only one direction from lower to upper side.
Thank you.
Thank you.
