When I removed the lower unit the lower shift shaft did not come with it. It is frozen/corroded to the upper connection. Any suggestions on the remedy for that when I put them back together? Is it an issue? Shifting was working prior to taking off the lower unit.
Separately, the impeller cap is frozen and I am having trouble getting it to free up. I haven't used penetrating oil yet or heat. Any suggestions?
Thanks!
Thanks!
