Bosunsmate
- Apr 7, 2012
- 6,129
Hello
Im fixing a starter motor on my friends merc as it was low powered. Ive found some carbon tracking through cracks in the washers on it so it was short circuiting and seems to power up fine now on my work bench which is my floor.
The spring under the top nut that pushes the bendix down has broken apart too.
Is this a necessity to fix? Doesnt gravity and the spinning of the motor once its started and the starter circuit is turned off make it fall back down? Im wondering if the only cause of concern would be if the bendix lifted up when going over a wave etc and engaging with the flywheel but this seems like it has a minimal chance of occurrence.
Thanks in advance
Thanks in advance
