Dear all,
I have recently bought Merc 80HP 2010 EFI 1,73L ("produced in USA; customized by Brunswick Belgium") and as I can see (youtube movies/tutorials and manuals with parts list) it is the same as 75/90(115) for US.
I have already read about two ways of converting 75 to 115 : The first one is by sending ECM for reflashing (follwed by removing restrictor plate/washer) and AFAIR the second one includes only ECM swapping(with 115 HP one, of course) and restrictor plate removing.
If I only change existing ECM (897727 22T - according to part numbers EU version with my SN should be 22T) with one used on 115 HP (897727 21T) will it work without any modifications (I have replaced AirFilter and there was no restrictor plate in my motor)? Any issues/incompatibilities could be expected since existing ECM (80HP) is for EU and desired one (115HP) is for US market?
If this "ECM swap" will work I would like to hear your opinion (I havre really no experience)... Is it better option than sending it for reflashing (cause it is at least $300 cheaper and I still have my working ECM as a spare part or I can sell it)???
Which is the easiest way to find out gear ratio of my engine (only 115 should have 2.07 while all other should have 2.33) without disassembling it? Currently I have 13x19P propeller and as far as I know from previous owners it is stock propeller BUT what I noticed is that with this setup (13x19P prop; 5.1 m fisherman boat which weights about 750 kg; 2 persons and 100 kg extra load) I cannot reach more than 5200 rpm while speed is cca 30 kts. Is this then an "overkill" for this motor since declared max rpm should be 6000?
Thanks in advance..
Thanks in advance..
