sbwhip1782
- Sep 24, 2015
- 17
Hello All,
This is my first post so please bear with me. I have a 16' Galstron Tri Hull with a 1975 Merc 402 40HP thunderbolt ignition, merc controls. The motor does not have power trim. I am not getting all the RPM's out of the motor when in the water. It will rev all the way when out of the water (I know the drag while in the water will not allow me to reach the same RPM's as I get when out of the water). That being said I know the motor is capable of more. I believe this to be a trim, prop, or linkage problem. The old man who gave me the boat only ran it in the lake. I use the boat almost exclusively in salt water.
So my questions are:
1. Has anyone else experienced a similar problem with a comparable set-up? If so what was your solution?
2. If the motor is propped wrong does anyone have a prop recommendation?
Thank you all in advance for the help. Safe boating!
Best,
Jason
Best,
Jason
