Chemdawg
- Aug 31, 2013
- 112
Hello everyone. Not sure if this should go here or under the electrical forum. Figured here since it's engine related. So my boat was running at the end of the season, and I parked it over the winter. Now I have it out of storage, and was going to fire it up for the first time to set the carb up after the carb rebuild. Wont' start. Checked fuel. That's good. Checked spark. NONE. I took the wire right off the coil and put it close to metal like I normally do, and turned the engine over. No spark coming from the coil. Checked the 12v at the coil. Good. Checked the ground at the coil and that was good. Is it possible that my coil went bad? Seems weird that it's been sitting and now I have no spark.
