thegoat86
- Oct 12, 2014
- 117
Traded for a Larson boat, now I have found some issues with the wiring. I cant get the boat to shut off. I choke it out through carb to kill. Tested the ign switch, shuts off continuity fine, but I have a back feed when running. Feel it is wiring where the motor was replaced. I have a few other wires curiously not hooked up as well. Plus the fuel pump is wired to the coil +. I read it should run through the oil pressure switch?? I tried Iboats manuals but cant find the appropriate diagram for the 4.3 vortec. soooo any help would be greatly appreciated. thanks
