Fiat4Fun
- Sep 14, 2009
- 215
Howdy, I have a 1986 Mercruiser with 260 HP V8, and the motor still has the original rubber riser pipes. There is a rubber pipe that comes off the riser, to a right angle metal pipe, and then another rubber boot that goes to the exhaust pipe "Y". Both sets are held in place with a pair of stainless hose clamps in each end. I suspect that water may be dripping out one side or the other, as I have had to tighten the clamps earlier this year.
Should these be replaced at a certain time? Boat has over 700 hours on it, and these are original. I am thinking that maybe these have shrunk over time an water may be leaking into the bilge.
Any thoughts would be appreciated
Thanks
Thanks
