Hey guys, I have a 1996 Bayliner 2252 with a 5.7L Mercruiser. I got it from my in-laws back in 2009 as they had it sitting in a garage for about 10 years. I pumped all the gas out of it and rebuilt the carb as the gas had varnished. Once I ensured it was clean, I started it up. The boat runs beautifully with great cold starts and idles perfectly. Performance while running is perfect as well. The only problem I have is that once it is heat-soaked and I shut it off, say, to change skiers, the engine starts as if it is flooded. I have to go to wide-open throttle to start it back up and then it is back to a beautiful idle and great running. Any ideas on what this may be? I talked to someone at Mike's Carb in WA and he thought the fuel may be getting too hot and boiling. I am not sure how to correct this even if the fuel is getting to hot. Again, with the hose hooked up to it in the driveway, I can't reproduce this condition. Must not be under enough load to get the temp I need to simulate this condition.
Any help is appreciated.
