Hey everyone,
So here's a quick run down on the situation. Boat is an 88 Four Winns with an 88 Mercruiser 3.0. Bought the boat late last season. In my only time out with it, it ran fine for about 15 minutes and then died and wouldn't restart. Restarted at home on trailer without issue. Found bad head gasket and replaced that which included machining head. Replaced impeller and rebuilt carb as well. This season, getting it all buttoned up from repairs. It has a noticeable skip and stalls at idle. Temp gauge wasn't moving at all after running it for 10 minutes. Checked today and found stuck open t-stat. Replaced that and the fuel/water separator filter. After replacing these two items, engine will not start. Found it now has no spark (odd as it was fine yesterday) Pulled the cap (didn't look bad, but new one ordered and on the way). What I did find was that it has the electronic ignition conversion kit done. Serial on it is 05AD-V5, but can't figure out which kit was used. I tried attahcing a pic to the post, but it keeps giving an error. Did a little homework and found that the conversion kit needs to have a new coil used with it. (I think) Mine has the original coil, which is only putting out 8v, and I believe the upgrade needs 12v. So my question after all this, is it possible that having the wrong coil being used was the cause of the whole engine dying when I took it out? Maybe it was overworked and overheated and stopped firing? I've already ordered a Pertronix Ignitor II and a Flame Thrower II for it.
Thanks for any help!! This boat will be the death of me!!!!
