Re: New to Mercruiser and lots of questions
I purchased a boat last year that had tilt/trim problems, starter wouldn’t engage. I have had boats in the past but this is my first ski boat and first inboard. I was told the motor is a 1980 or 81 470 (serial #5702789 outdrive serial #5643302).
That's a 1980 (engine and drive), and the drive is an MC-1...
PFJ said:
The tilt/trim motor is running real slow, and he said that he had the motor rebuilt but still the same problem no matter the direction.
When you say 'rebuilt', define. If it was just opened up and cleaned, that is not a 'rebuild'. I would open it up and check the brushes, commutator and bushings/bearings... Also check all the electrical connections are clean and making good contact. I would also check for voltage drop in the supply circuits.
PFJ said:
I was looking at complete units but the one on iBoat (
Hydraullc Trim Pump Assy. - Metal Bracket - Sierra 18-6752) says 1983 and later without quick connect fittings. R, MR, Alpha, Alpha Gen II and Bravo. Are there and conversion or connector changers to get this one to work? If this can’t work I will have to just buy the motor and new reservoir.
For your engine, have a look at this one.
Mariner, Mercury Marine, Mercruiser Inboard Replacement Power Tilt and Trim Motor 6217 - Arco
PFJ said:
What fluid should I use in the tilt/trim?
In the trim you can use either ATF or light weight engine oil (SAE20)
PFJ said:
What version is my out drive? It talks about alpha, alpha 2 just wanted to know what mine was.
You have a 'Mercruiser-1' drive, or MC-1 (they ran from 1967 to 1982), and the drive ratio should be 1.84:1
PFJ said:
The starter isn’t doing anything just buzzing I thought about taking it to a rebuild shop and getting them to repair it. The repair shops do automotive starters is there a real difference between automotive and marine?
The differences between marine and automotive starters is the spark/flash arresting. Inside a marine starter will be a couple of screens to stop direct exposure between fuel vapours and the starter-motor brushes. The auto-sparky should be a good place to get the starter reconditioned.
PFJ said:
I also want to change it to electronic ignition, add an electric fuel pump, and change all the fluids. I found the electronic ignition conversion kit on iBoat, but I don’t know what electric fuel pump to get.
Electronic ignition is a great idea, but stay with the mechanical pump you have. Also, before you start changing all sorts of things, get the engine running properly first. Much easier to change a working engine than trying to find old problems with new (unknown) parts in....
PFJ said:
What fluids do I need to buy for this engine, outdrive, and things I need to flush or clean since the motor hasn’t been run in two years? Thanks for all your help I’m new to this part of boating and I need lots of help.
Engine uses normal engine oil, 20W40 or 20W50. Your engine also has coolant. I would remove the heat exchanger and have it cleaned out and checked by a radiator specialist. Refill with new coolant. The drive should ONLY be filled with Quicksilver/Mercury 'High Performance Gear Lube'.... If the engine has power steering use the same fluid as the trim system....
If you don't have a proper factory manual (seloc and clymer are NOT manuals, they are knee-pads), let me know and I'll post a link for you to download.
Chris........
