Motor shuts down when applying gas in reverse
Len L
I have a Mercruiser MCM 165/3.7 liter. It shifts in and out of gears fine and accelerates normally in forward. When I am in reverse and idling, the motor runs fine. The problem is as soon I start to apply more gas in reverse, the motor stops instantly. This has proven to be dangerous and embarrassing. Can anyone provide a remedy? Thanks.
thumpar
Re: Motor shuts down when applying gas in reverse
With the motor off have someone work the controls while you watch the shift interrupt switch actions.
Bt Doctur
cable adjustment if increasing throttle causes the switch to activate
