Chemdawg
- Aug 31, 2013
- 112
Hello everyone. Over the winter I rebuilt my Alpha one outdrive. All new seals, etc.... I pressure tested it and vacuum tested it, and it worked out great. I also replaced both bellows and shift cable, and bellows for that. I put the outdrive back on today, and did a reverse type flow test. I took the hose off the thermostat housing, and ran water through it to the outdrive.
So here's my questions. I had water coming out the shark fins, prop, and where the front bolt is by the shift linkage, there is a hole behind the bolt that water was coming out of.
Are these all normal places for water to go in or out?
