Hello again. I have been tying up all the loose ends on this boat. Finally got around to asking this question that is a little puzzling for me.
This is a 95 3.0LX with Alpha One.
I occasionally put the drive in a tub of water and run it for a while just to keep it happy. I notice when I do this, the impeller pumps water up into the engine (I am sure of it because I felt for the suction). There is no water coming out of the exhaust bellows for several minutes. I noticed that once the temperature gauge climbs up to a certain point (can't remember exactly where) I finally get water coming out of the exhaust. The temperature goes back down to almost zero and stays there. The water will continue to come out of the exhaust as long as it is running. So is this normal? Hanging thermostat?
This almost cant be normal because the manifold/riser or whatever it's called has got to be incredibly hot and then dumping water through it can not be a good thing.
I get about 80% of the water out of the right side port. The rest comes out of the left. Is this normal? I don't recall why there are even two sides when there are only 4 cylinders inline.
But the weirdest thing - while I am waiting for the water to start pumping out, there is a constant rattle coming from those ports. Almost sounds like bells ringing around in there. As soon as the water starts flowing, it goes away. Any help would be greatly appreciated as I have no one within about 80 miles that will even look at it - not to mention I enjoy the DIY aspect, but don't want to ruin stuff due to sheer ignorance. I can take a video if that would help.
Thank you in advance for any advice,
BL
BL
