acdc96
- Apr 23, 2013
- 412
Yesterday I started my motor and ran it for a bit to do a oil change. While going to increase the throttle a bit I accidentally hit the reverse and forgot to push the throttle button and the drive had a clunking/clicking noise. I put it in neutral and waited a min then I put it in forward gear and it sounded fine. I stop the engine and restarted it and put it in reverse and the sound still occurred. I stopped the motor and check the prop to see if it was loose and it was fine. I turn it clockwise and it was smooth, them turned it counter clockwise and it clicked.
Could this be the shift shoe? I did recently replace the water pump and had a little difficulties putting the lower unit back on. The drive also has fresh gear oil in it.
Any ideas on the what the noise is?
1986 Mercruiser 260HP V8 w/ Alpha One Generation 1 Drive
