CaptainMak
- Apr 28, 2012
- 294
Took the 2003 5.0L Merc out this winter to fix an oil drip at the back of motor (flywheel area).
Replaced the oil pan gasket and rear main seal, making sure all corners and joints of the oil pan were properly sealed with RTV silicone.
Put everything together, popped the block into the boat, started up and got the same leak. After running the motor about 2 mins, I get a drip about every 5 - 10 seconds onto the bottom of the flywheel bellhousing (inside).
It seems like it's dripping off the main seal, but with limited space it's hard to see if it's dripping from there or dripping down the block and then off the main seal housing. I KNEW I should have run it on stands before popping it back in. :faint2:
Anything else that could be causing the engine oil leak back there ? I've looked, I don't see anything else it might be.
