Liquid on outdrive
Samckay
I was getting my boat out of storage and was going to lift the foot and noted this oily stain on both sides of outdrive. Was getting ready to change impeller anyway and wanted to know what else i should look at as the source. Saw several other boats in the facility w/o similar stains... '
Any idea what it is from and do i need to fix?
was stored thru winter in SC, foot down
MarkSee
Re: Liquid on outdrive
Looks like it could outdrive gear oil.
When you pull the drive to do the impeller, first pressure test the drive.
Mark
achris
More fish than mountain goat
Have a read of THIS.... It's specifically for drives up to 1991, but it should help you with your leak.
Chris....
Samckay
Could this have been leaking for a while because I did have to top up the outdrive oil sev times last year
Do i have to pull off the whole outdrive to check or can I do it in place? is it hard to pressure test? Where do i attach the pressure gauge?
Thanks
Fishermark
The link that Chris posted answers most of your questions... here's a pic from the link:
attachment.php
achris
If you have the gear lube monitor bottle, you MUST pull the drive to do the pressure test....
